77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Model Fill Patterns
Fri, May 28, 2010 at 10:19:18 AM | Model Fill Patterns
atripodi
Hi!  I am working on a finish plan for a project using Revit 2011, and am trying to draw filled regions to detail a tile layout.  I'd like to use model fill patterns, but for some reason the filled region type, it only allows me to select drafting patterns, and the model pattern option is greyed out.  I'm not sure if this is because I'm using 2011, since I don't recall having this issue with previous versions.  How can I fix it so that I can use the model patterns?
Fri, May 28, 2010 at 1:26:05 PM | Model Fill Patterns
4 Stars: 203 Votes
Wierd, it's fine with me...
Tue, Jun 22, 2010 at 11:35:20 PM | Model Fill Patterns
seyedsaleh
seyedsaleh Avatar
you may need to this directly from material properties,
seyedsaleh@gmail.com
 0098 912 77 111 35 (tehran-iran)
0097 150 90 60 879 (dubai)
Fill Patterns Drafting / Model
Tue, Sep 8, 2009 at 8:06:41 AM
Rotate Model Fill Patterns
Wed, Sep 2, 2009 at 11:01:19 AM
14
Perpsective Fill Patterns
Mon, May 10, 2010 at 6:12:51 PM
model fill patterns
Fri, Sep 23, 2005 at 11:57:55 AM
Fill Patterns
Mon, Mar 10, 2008 at 6:40:10 AM
Page generation time: 0.7852
