47 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> sloped glasing
10 Posts No Rating |
hello I made a sloped glasing roof and when I put the mullions it seems that they are allways orientated to the outside. is there a possibility to chage the position of the mullions so that they appere on the inside? thank you
When you click on that mullion and you go to properties you have a "Offset" parameter, then "Play" with negative / positive values...
thank you, it helped a lot.
Metal roof - Sloped glazing problems on egdes |
Wed, Mar 5, 2008 at 2:28:37 PM
Dome with Curtain wall-Help on flat surfaces |
Tue, Sep 13, 2005 at 6:45:20 PM
Sloped terrain and sloped foundation wall |
Thu, Sep 3, 2009 at 1:57:36 PM
sloped walls |
Wed, Oct 13, 2010 at 1:28:16 PM
Sloped Railing |
Fri, Nov 21, 2008 at 11:31:01 AM
Members: | 2017227 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
