97 Users Online (95 Members):
Forums >> Revit Building >> Technical Support >> Floor with Slope AND Variable Thickness?
1 Posts No Rating |
Does anyone know of a way to create a floor or structural slab that is both sloped AND has a variable thickness?I can do either, but not both to the same floor. Thinking that I may need to create a generic mass.
I don't have Revit right now to create a video or some screenshots to show you but in the properties of that salb go to edit/new then in the function(layers) you must have at least 2 functions, you must turn ON the Variable of the function you want (top or bottom), then, when you are sketching the slab you have a tool to create the slope "Slope Arrow", use it, after finish the sketch when you click on the slab, in the options menu (ribbon) you will see tools for that slab, use "modify Sub-Elements".... Check your HELP menu if you have some doubts....
Edited on: Fri, May 28, 2010 at 12:35:06 PM
I'm not sure if this actually addresses the original question. I am going through a similar dilemma in that I need the deck (1st layer) to consistently slope across a given plane and also have the insulation be variable (2nd layer).
You can not do both functions - roof slope and varied thickness using the normal roof tools.
You can do extrusions and voids - probably by layer - to do this.
Roof with variable thickness on sloping framing |
Wed, Jan 20, 2010 at 10:12:06 AM
Variable Thickness Wall? |
Fri, Feb 10, 2017 at 6:09:58 PM
Wall Thickness variable |
Tue, Apr 12, 2005 at 11:37:44 AM
Floors not being cut in sections in 2013 |
Fri, Jan 11, 2013 at 8:44:07 AM
Floor drain slopes adding lines to the slope when modifying sub elements |
Tue, Oct 16, 2012 at 3:55:57 PM
Members: | 2022253 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
