Forums >> Revit Building >> Technical Support >> Revit 2011 Hang on Material Painter
3 Posts No Rating |
Hi All, Every time i try to paint a material onto a wall the box just freezes. I can select material painter, the drop down appears then when I try to scroll to the desired material the program hangs. I am currently in trial mode with the 2011 version anyone else experienced this? Many thanks
I never had that kind of problem and I don't have information about this is a kind of Bug....
3 Posts No Rating |
Oh dear! This is becoming a real pain in the proverbial! Anyone shed any light or had similar problem
3 Posts No Rating |
*FIXED* Basically having audited and purged everything from my drawing to no avail I started to look at the materials in the material library. There were several non english descriptions for materials that I did not recognise so I deleted them, saved and re-tried the material painter and hey presto it worked. I can only assume the 'incompatible' materials came from object downloads done previously.
thanks for the info.
Same material looks different when rendered Revit 2011 |
Sun, Jan 2, 2011 at 8:12:10 PM
Revit 2011 products hang when creating or opening a project |
Thu, Oct 14, 2010 at 5:04:29 PM
What happen to the material properties in Revit 2011 |
Tue, May 11, 2010 at 9:40:46 AM
2011 revit: selected material/color does not show up |
Tue, Jun 8, 2010 at 3:41:55 AM
2011 change material color [ 1 2 ] |
Sat, Aug 31, 2013 at 8:46:22 AM
16
Members: | 2104043 | Objects: | 23178 | Forum Posts: | 152298 | Job Listings: | 3 |
