88 Users Online (87 Members):
Forums >> Revit Building >> Technical Support >> Stacked Wall Dimensioning
41 Posts No Rating |
howdy, Has anyone else had a problem with getting a dimension to lock on to a stacked wall? I am having all sorts of trouble in Revit 2010. Wondering if its a bug or if im doing something wrong... All other walls work fine! Thanks in advance
You have not given us enough information to answer your question. What are you dimensioning, a plan, a section, an elevation, opening in a stack? A little gif image will tell a lot. Screenhunter is free and it can capture a partial screen image with a very small file.
thanks for your time WWHUb, i wont waste any more of it! when i turned my machine on this morning and fired up Revit the problem had righted itself. it does this to me often and its incredibly annoying because i have to restart Revit. It must be a glitch caused by lack of memory. i would attach a screenshot but it wont really help - all i am doing is dimensioning simple wall setouts in a callout plan - 99 out of 100 walls will let me place a dimension to the wall core face, but the 100th wall will spit the dummy, and in this case it happened to be a stacked wall, hence my question. thanks again.
stacked wall line visable on the wrong side? |
Wed, May 6, 2009 at 10:51:58 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed |
Thu, Jan 24, 2013 at 8:06:06 PM
Scheduling of Stacked Walls |
Tue, Aug 18, 2009 at 2:16:01 PM
Breaking apart a Stacked Wall Issue |
Wed, Mar 11, 2009 at 12:03:44 PM
Staggered Stacked Wall Join Problems |
Tue, Oct 14, 2008 at 12:50:52 PM
Members: | 2057605 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
