162 Users Online (161 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Offset tile pattern
Tue, May 25, 2010 at 2:54:01 PM | Offset tile pattern
leothelionator
Is there a way to offset a 12x12 wall tile pattern so that the module begins 6" above the floor?  We have a 6x12 base followed by 12x12 wall pattern above.  I tried doing this with a stacked wall, but Revit will inevitably show the tile pattern module beginning at finish floor regardless of where the actual 12x12 pattern begins.
Tue, May 25, 2010 at 3:01:47 PM | Offset tile pattern
Do you want the material correct or just visually accurate?
I like accurate:
I use thin walls for tile.  In this case a stacked wall with the lower wall 6" hi and the other tile stacked on that to whatever height you want.  After you place this wall agaist your base wall, simply join the two and doors / windows will cut both.
BTW - You want the tile pattern to be a model hatch.  Then in elevation, you can adjust the patterns in both directions on either part of the stacked wall.
If the wall already has the tile finish assigned and the vertical joits will stack between the two tiles, simple adjust the model hatch in elevation (must be a model hatch).
To adjust model hatches, click on the hatch line and move it or even rotate it....
Tue, May 25, 2010 at 3:07:38 PM | Offset tile pattern
4 Stars: 202 Votes
If it's a Model Pattern you can select that Model lines pattern with the TAB key and then you can Move, rotate and align....
Edited on: Wed, May 26, 2010 at 12:35:29 PM
Tue, May 25, 2010 at 3:15:25 PM | Offset tile pattern
leothelionator
Thanks!  The model hatch adjustment is what I was looking for!  I am using model lines, but I couldn't figure out how to talk to the tile joint and not the wall.  You simply have to hit tab so that it toggles from the wall to the tile.
Wed, Jan 1, 2014 at 9:27:18 AM | Offset tile pattern
Krr27
I'm trying to do a 12 x 12 tile pattern...floor and wall.  The lines are a brick type pattern.  It doesn't allow me to save the 8 x 16 block pattern I see and change that to a 12 x 12.  I can't pick on my already made 12 x 12 ortho pattern as it just moves all the lines together.  I have tried the on line tutorials for a custom pattern and have not been successful. If anyone can help that would be greatly appreciated!  thanks!
Wed, Jan 1, 2014 at 5:56:14 PM | Offset tile pattern
hugh
3.5 Stars: 4 Votes
Try this pattern:
;%VERSION=3.0
;%UNITS=INCH
*12X12TILE-BRICK
;%TYPE=MODEL
;        Pattern written by HatchKit v2.7 Hatch Pattern Editor
;        HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2014.
;        www.cadro.com.au/hatchkit/
;-Template=NEW,
;-Date    =2/01/2014
;-Time    =10:52:21 AM
;-HatchKitVersion=2.7.1.1995
90,0,0,12,6,12,-12
0,0,0,0,12
hth,
Hugh Adamson
www.hatchkit.com.au
Custom Offset tile pattern with four sizes
Mon, Aug 8, 2011 at 11:48:11 AM
Make realistic tile pattern
Fri, Jun 25, 2010 at 9:43:54 AM
Material Pattern Alignment
Thu, Feb 24, 2011 at 3:35:54 PM
Tile Pattern Height
Mon, Oct 9, 2006 at 2:36:03 PM
Tile Pattern
Sat, Mar 24, 2012 at 7:10:39 AM
Page generation time: 1.1203
