71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Visibiliy of components
Mon, May 24, 2010 at 2:50:47 PM | Visibiliy of components
bellgroup
I have inserted a cooktop into a cabinet that is not visable in the floor plan view but is visable in an elevation view. However there is a sink that is next to it that is visable.
Mon, May 24, 2010 at 3:03:00 PM | Visibiliy of components
4 Stars: 203 Votes
Edit the family, click on that "Cooktop" and check "Visibility"...
Mon, May 24, 2010 at 3:52:22 PM | Typhoon
bellgroup
Quoting Typhoon from 2010-05-24 15:02:59
Thanks for your post, but here is what happened. First of all it worked but when I tried to save as it said that itwas read only are was open somewhere else. So I just saved as another name but I could not see the other cooktop that was nserted no matter how many objects I turned off. If I went to the view of 2nd floor I could see the 2nd cooktop was still incerted in the drawing. What do I do about this to remove it.
Tue, May 25, 2010 at 6:27:14 AM | Visibiliy of components
4 Stars: 203 Votes
In that 2nd floor select that zone by "Crossing" then go to "Filter" and leave "ON" ONLY that family you want, then delete...
Tue, May 25, 2010 at 11:11:03 AM | Visibiliy of components
bellgroup
I'm soory but I'm not sure what you mean by crossing. Do you mean window around it , if so I tried it but did not find the filter command. Maybe I was on the wrong tab. Please give me some detail. I appreciate all of your help.
Tue, May 25, 2010 at 11:22:11 AM | Visibiliy of components
From your HELP (I added comments in BOLD):  Selecting Multiple Elements
To select more than one element, use one of the following methods:•    While pressing CTRL, click each of the elements. •    Draw a selection box by placing the cursor on one side of the elements to be selected and dragging it diagonally to form a rectangular boundary.
<THIS IS A WINDOW>
o    To select only elements that are completely within the boundary of the selection box, drag the cursor from left to right.
<THIS IS A CROSSING>
o    To select any elements that are wholly or partially within the boundary of the selection box, drag the cursor from right to left.
•    Press TAB to highlight connected elements, and then click to select. See Selecting Chains of Walls and Lines. •    Right-click on a family type name in the Project Browser or a family type in the drawing area, and click Select All Instances. This tool selects all instances of that family type in your project. See Project Browser. NoteIf you are editing a design option, the tool name is Select All Instances in Active Option. It selects all elements of that type in the active option only.
Tue, May 25, 2010 at 2:08:40 PM | Visibiliy of components
4 Stars: 203 Votes
Just to show you where is the "Filter" tool.... WW said the rest...
Components on Level are Grey
Wed, Apr 17, 2013 at 12:56:07 PM
problem loading components
Sun, Apr 26, 2009 at 2:21:19 PM
transferring components
Tue, Jul 29, 2008 at 3:51:01 AM
Visibility/Graphics and Detail Components
Wed, Feb 23, 2011 at 2:53:37 PM
deleting old components
Sat, Apr 11, 2009 at 12:28:13 PM
Page generation time: 0.7254
