56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> OPenings through multiple walls?
Mon, May 24, 2010 at 1:47:12 PM | OPenings through multiple walls?
PatrickReynolds
PatrickReynolds Avatar
Hello.  I'm currently working on a project that has pre-definied walls with window systems already laid out.  We are adding an additional layer of wall to provide space for electrical wires and the like.  I've create the wall with the appropriate strucutre, and am setting it against the existing wall.
My question is, is there a method by which I can have the new wall adopt the openings of the existing wall?
I cannot simply add the structural layers to the existing walls because of phasing complications; they have to be seperate walls.  I know I can achieve this effect by putting openings in the wall, but that method is very time consuming.  Does anyone know an easier way?
Thanks in advance
-Patrick
Mon, May 24, 2010 at 2:11:17 PM | OPenings through multiple walls?
Simply use the join geometry tool selecting one wall then the other and the openings will cut both walls.
Mon, May 24, 2010 at 2:28:41 PM | OPenings through multiple walls?
PatrickReynolds
That worked perfectly, thank you very much. ^^
Mon, May 24, 2010 at 4:42:02 PM | WWHub
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting WWHub from 2010-05-24 14:11:17
"Simply use the join geometry tool selecting one wall then the other and the openings will cut both walls."
Smile
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, May 24, 2010 at 4:48:54 PM | OPenings through multiple walls?
:-)  You remember coreed - thanks again for pointing me to that one.
Openings in (Structural) Walls Scheduling as Non-Bearing Walls
Thu, Feb 21, 2008 at 5:55:28 PM
Curved wall openings
Fri, Oct 15, 2010 at 12:42:11 AM
Revit 2011-putting openings in angled walls.
Sat, Sep 10, 2011 at 5:45:27 AM
circular openings in concrete walls
Fri, Jan 11, 2008 at 1:05:05 AM
Copy/Monitor Openings
Tue, Aug 9, 2016 at 3:41:46 PM
Page generation time: 0.9530
