45 Users Online (44 Members):
Forums >> Revit Building >> Technical Support >> How to pin irregular (custom spaced) horizontal curtain wall grid
3 Posts No Rating |
Is there a way to move horizontal curtain wall grid at irregular (custom) spacing and then pin the grid so that any new curtain wall drawn afterwards to retain the spacing of the horizontal mullions. The goal is to have the new walls created later to keep the custom horizontal spacing of the curtain grid. (for Revit 2009). Thanks!
![carrucha75 Avatar](user_avatar/78110.jpg)
![4 Stars: 24 Votes](/images/stars_4.gif) |
tonini look at the botton of this page there are some tread about your question i guess.
Not Sure What Revit Can Do?... Find it OUT!!!
“Imagination is more important than knowledge...” -Albert Einstein |
3 Posts No Rating |
...from what I read it does not seem possible to define custom horizontal curtain wall grid that is re-created with the same spacing when a new segment of the same wall type is drawn...may be in the next version...Thanks for the help!
Did you just try and copy your irregular spaced CW to another location?
3 Posts No Rating |
coping the wall (with irregular horizontal mullion spacing) and then adjusting the lenght by stretching or aligning works!...simple... I should've thought of it...thanks for the tip!
Curtain walls: Different spacings between mullions. |
Tue, Jun 2, 2015 at 9:46:09 AM
curtain wall super custom grid |
Fri, Sep 11, 2015 at 9:41:09 AM
Curtain Wall Grid Issues |
Tue, Dec 23, 2008 at 8:47:00 AM
Curtain wall grid |
Sat, May 28, 2016 at 9:58:45 AM
Revit 2013 Curtain Wall Variable Grid Spacing |
Thu, Jul 18, 2013 at 2:10:54 AM
Members: | 2022252 | Objects: | 22975 | Forum Posts: | 152202 | Job Listings: | 3 |
