57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> creating a elevation view on a non parallel wall
Mon, May 24, 2010 at 11:07:13 AM | creating a elevation view on a non parallel wall
gordi
i have a wall that slopes upwards and angles also in plan view and i want to create an elevation view which sits parallel to these angles. is there any way to do this
Mon, May 24, 2010 at 11:56:33 AM | creating a elevation view on a non parallel wall
You need to create a section that is rotated to match those angles.
Wed, May 26, 2010 at 8:29:47 AM | creating a elevation view on a non parallel wall
gordi
i can seem to rotate a section to view what i want parrallel. see attatched image. is there any way to do this.
Wed, May 26, 2010 at 10:06:58 AM | creating a elevation view on a non parallel wall
gordi,
Look at the attached image.  This was done for someone that wanted a view normal to a sloping roof but the same applies to what you want.
Simply
  1. ut a section that looks at your wall,
  2. then in a perpindicular view,  select your section
  3. pick rotat, and move the rotation center to any point along the face of your wall
  4. and rotate to another point along the wallface.
Now your section is parallel to the wall.
Revit 2013 - realign elevation view parallel to wall
Tue, Oct 16, 2012 at 3:07:52 PM
Defining elevation views parallel to a reference plane
Sun, Mar 5, 2006 at 2:37:41 PM
Callout/ Section/ Elevation marks on parallel plans
Wed, Feb 22, 2006 at 5:56:30 PM
Parallel angled millions
Tue, Feb 6, 2007 at 6:47:36 PM
Parallel sections show up in an elevation view
Sun, Nov 22, 2020 at 12:07:40 PM
13
Page generation time: 1.6126
