47 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Where to find detach all for walls in Revit 2011?
Sat, May 22, 2010 at 12:11:20 PM | Where to find detach all for walls in Revit 2011?
usoniani
Even in help says something related to old non ribbon Revits!
Sat, May 22, 2010 at 12:48:01 PM | Where to find detach all for walls in Revit 2011?
4 Stars: 203 Votes
Are you talking about the Attach / Detach button of walls?
Sat, May 22, 2010 at 12:52:14 PM | Where to find detach all for walls in Revit 2011?
usoniani
No it was function in the bar (not ribbon) detach all, you simple select wall click it and wall or walls get detached from all targets!
Now I cant find it, even in help is not described!
Cannot detach from central !!! plz help !!!
Fri, Sep 17, 2010 at 8:17:44 AM
Detach WALL from unknown object
Sat, Jul 7, 2012 at 4:44:45 AM
Column Base Attachements - RS 2011
Mon, Nov 22, 2010 at 9:22:52 AM
detach from central file
Wed, May 12, 2010 at 12:28:23 PM
Wall detach
Tue, Feb 23, 2010 at 8:09:07 PM
Page generation time: 3.4358
