Forums >> Revit Building >> Technical Support >> Callout head wont display
Ive tried everything to get my callout head to show. one project has it, the other wont. i place the callout rectangle, but the head never appears. where is the option to turn this on and off. I have done no changes from one project to the other so I dont know where or why this happened. the callout view is created and can be placed on a sheet too. thanks revit 2009
What version of Revit? Go to Settings....
1 Posts No Rating |
I'm having the same problem. Revit Architecture 2011
Yeah, so I went back over the step line out in my Mastering revit 2009 book and was able to reload the call out heads I created. I think also I was trying to create a callout inside a callout or something, so maybe I was doing something wrong, either way the problem worked itself out. I wish I had more info for the previous post, but I messed around with my views and got the curse worked out. Ill repsond to an email if one needs to chat more too. -michael
Rotate Callout Head? |
Thu, Aug 1, 2019 at 10:08:03 AM
callout only head |
Tue, Mar 26, 2013 at 7:09:21 AM
Add view name to Callout Head |
Wed, Feb 22, 2012 at 9:40:26 AM
Detail callout head size variable? |
Wed, Mar 6, 2019 at 4:26:36 PM
Dummy Callout Heads |
Tue, Jan 28, 2014 at 3:35:51 PM
Members: | 2101751 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
