74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Hide Spot Elevation Leader
Wed, May 19, 2010 at 11:04:59 AM | Hide Spot Elevation Leader
leotrans
Hi,
anybody know how I can hide the leader line from spot elevations.
there are too many, and drawing is full of lines..
I tried to make it just white color, but then it appears over dark objects
any ideas?
thank you!
Wed, May 19, 2010 at 12:45:04 PM | Hide Spot Elevation Leader
4 Stars: 201 Votes
When you click on spot elevation you will see in option bar "Leader"
Wed, May 19, 2010 at 12:47:58 PM | Hide Spot Elevation Leader
leotrans
thanks, but I meant something else:
 when I place spot elevations, I need the leaders so that I move the spot elevation at the side of the elevation
(for example when I am referencing  a window sil height)
but when I export pdf, this leader line is visible - can it be hidden?
thanks again!
Wed, May 19, 2010 at 1:11:29 PM | Hide Spot Elevation Leader
3.5 Stars: 395 Votes
Your last post is very confusing.  You say you need the leader but you want to hide it.... contradictory
Perhaps you can make this clearer by adding an image and pointing to your problem.
Wed, May 19, 2010 at 1:30:23 PM | Hide Spot Elevation Leader
leotrans
I am sorry about that,
here's a capture.
I've turned the leader lines in White color to be as hidden as possible,
but when I export they are still visivle over a dark background
I just need them to be completely hidden
thanks again!
Wed, May 19, 2010 at 2:22:47 PM | Hide Spot Elevation Leader
rev2010
leotrans, yuor elevation looks great, it's quite simple to turn the leader off, see instant property, uncheck leader or shoulder.
Edited on: Wed, May 19, 2010 at 2:37:48 PM
Wed, May 19, 2010 at 2:52:59 PM | Hide Spot Elevation Leader
leotrans
thanks,
I tried that, and the moment I uncheck the box the spot elevation moves to the location where the leader
starts.
I was wondering if it is possible to keep it outside the elevation edges but without the leader line
One way maybe it to use reference planes.. but then it needs too many.
thanks again!
Tue, Apr 8, 2008 at 10:05:36 PM
border on a spot elevation tag
Fri, Jan 29, 2016 at 2:52:39 PM
Spot Elevation Forced Text
Fri, Apr 22, 2011 at 1:04:00 PM
Elevation Tag - Leader Problem
Thu, May 17, 2012 at 5:48:20 PM
Spot Elevation vs. Level elevation
Wed, Feb 14, 2018 at 6:13:20 PM
Page generation time: 0.5301
