23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit ROI >> Advice on strip windows
Tue, May 18, 2010 at 2:48:15 PM | Advice on strip windows
archie456
3 Stars: 1 Votes
Hi,
I'm modelling a load of windows in a building. Essentially, its one window about 25m long subdivided into individual panes 1.5m wide each. The window is 2.2m high.
Whats the best way of creating this - should I use a window or a curtain wall?
Could anyone point me to some good tutorials on this?
Cheers.
Tue, May 18, 2010 at 3:06:42 PM | Advice on strip windows
TomDorner
4.5 Stars: 25 Votes
I would personally use a curtain wall.  You can create a new type that is set to automatically embed itself into another wall, predefine the horiz and vert spacing and the mullions.  Curtain walls have an instance parameter for beginning, center and end alignment of the spacing.
If you use a curtain wall though, it will not schedule as a "window".  You can fake it using a fake window family that is aligned and locked to the extents of the curtain wall though.
The larger discussion I've always had with my students is: what is a window and what is a curtain wall?
The best definition I can come up with is that a window is a complete unit that arrives on the jobsite and is installed.
Curtain walls are a collection of parts that are assembled on-site.   Many times this occurs in stages of installing the mullions then coming back weeks later with glazing since it was custom measured and manufactured for each opening.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Wed, May 19, 2010 at 2:17:13 PM | Advice on strip windows
archie456
3 Stars: 1 Votes
I see - thanks.
So you can't get windows to schedule as a curtain wall?? that would be a problem.
Is it possible to do a large window made up from several panes - is there an out of the box family which does this?
Wed, May 19, 2010 at 8:52:05 PM | Advice on strip windows
mcantwell
mcantwell Avatar
Thu, May 20, 2010 at 2:54:32 PM | Advice on strip windows
archie456
3 Stars: 1 Votes
Excellent - Thanks for that.
Handrail Lighting LED Strip
Thu, Jan 11, 2018 at 6:31:22 AM
How to build a mobius strip in revit?
Mon, Aug 30, 2010 at 5:08:52 PM
How to Hide Door Transition Strip with Materials Finishes in RCP (Revit 09)
Thu, Sep 4, 2008 at 4:13:17 PM
Lighting strip - how to make one?
Wed, Jun 15, 2011 at 7:06:07 AM
Strip Footing Tags
Thu, Jul 26, 2007 at 8:25:31 AM
Page generation time: 1.1919
