Forums >> Revit Structure >> Technical Support >> Gable wall without using "Edit Profile"?
25 Posts No Rating |
I want to model a gable wall without using "Edit Profile". Is there any options there? Please help me.
unless you are attaching it to a gable roof, you would have to use some void geometry on the wall. what is the problem with using "edit profile"?
Well, only if the wall is an arc/curved?
Yes, I attached to the gable roof. Thank you. When using "Edit Profile", The top grip is in wrong place.
when the wall is selected there will be a tab that says modify wall, on that there is a tile that says top/base click attach under that tile and click the wall and then the roof. this will extend your wall to the underside of your gable roof.
----------------------------------- PWD |
edit wall profile... what? |
Mon, Feb 7, 2011 at 1:58:19 PM
"Dutch Gable" roof |
Mon, Mar 31, 2008 at 1:35:54 PM
railing profile in project - not available in edit rails |
Fri, Sep 21, 2007 at 11:50:52 AM
Using Edit Profile to Modify Curtain Wall Elevation |
Mon, Nov 8, 2010 at 12:08:55 PM
Stacked Wall with Wall Sweep |
Mon, Oct 5, 2009 at 4:34:41 PM
Members: | 2119230 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
