58 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Schedule of structure of wall
Tue, May 18, 2010 at 4:37:51 AM | Schedule of structure of wall
satheeshbabu
Is it possible to get the schedule of structure (layer) detail of the wall? I need the schedule of volume of each layers in the wall. Please help me.
Tue, May 18, 2010 at 4:40:35 PM | Schedule of structure of wall
TomDorner
4.5 Stars: 25 Votes
You can get a "Material Takeoff" schedule that will show the areas and volumes for each material in the project.  If you assign a material to each layer in the wall you can get each layer by material then.  The trick is going to be to filter down the results to just walls if that is what you want.  Material naming is probably the key.  If you name all the wall layer materials with a common beginning like wall - steel studs, wall- cmu, wall - ??? etc, then you can establish a filter that only displays materials that begin with "wall" which would give you what you want.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Wed, May 19, 2010 at 1:39:46 AM | Schedule of structure of wall
satheeshbabu
Thank you, Tom, It works. It is nice. This is what i want.
Structure layer of furring wall cleaning up with structure of concrete wall.
Mon, Nov 3, 2008 at 9:48:01 AM
snapping to wall structure
Thu, Apr 10, 2008 at 3:35:38 PM
Revit wall structure tracking
Mon, Nov 25, 2013 at 2:23:26 PM
11
Quick Wall Schedule Question?
Tue, Oct 21, 2008 at 12:40:22 PM
Split surface & paint vs. schedule
Tue, Oct 12, 2004 at 3:34:33 AM
Page generation time: 1.7207
