101 Users Online (100 Members):
Forums >> General Discussion >> Revit Project Management >> Turn Revit line to look like hand sketch lines
is there a way in Revit to turn a model or 2D line drawing to look like a hand sketch drawing ? I know it can be done in autodad but not sure if Revit allows to do that as well. thanks
Short answer: no Long answer: You can export Revit views a 2D CAD files and use whatever you would use in the CAD world to sqiggle the lines.
if you are on subscription at the download center you may download Autodesk Impression.... I'm pretty sure it's still free. You can then export DWF formats to Impression and quickly create sketchy hand rendered looks. Super easy program to learn, should take about 20 minutes to figure it out.
ok thanks, i able able to do it in CAD 2010 but only in 3D view, how/where can it be done in 2D? I know this is a revit forum and not CAD but any help is appreciated
As the previous post mentioned Autodesk Impression does a decent job with either dxf or dwg files and is free for subscription customers. There are other dedicated programs like Squiggle [do a web search]. You could export as dwg and use Sketchup. The list is probably endless.
Sketch Rendering |
Thu, Sep 30, 2010 at 10:13:46 AM
Split Face Sketch on Floor Completes then Displays Error: Line is Too Short |
Wed, May 22, 2013 at 3:12:37 PM
Filled Region Sketch Mode |
Tue, Nov 17, 2015 at 1:28:34 PM
Sketch Line Style |
Wed, Jun 25, 2008 at 2:19:10 PM
curtain wall sketch snapping problem |
Wed, Aug 12, 2009 at 8:54:07 AM
Members: | 2057700 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
