Forums >> Revit Systems >> Technical Support >> HOW TO ATTACH SLAB TO SLAB EDGE??
33 Posts No Rating |
any help?? revit 13
----------------------------------- IMAC 3.06GHZ,MACOSX 10.5.6 with WINDOW XP PROF, REVIT ARCH 2009,AUTOCAD 2009,VECTORWORKS 11.0,ARCHICAD 7.0,LEED AP. |
In slabs you have the "Slab Edge" tool, just use it, select the edges you want... REVIT 13 -----> ????? WHAT?????
Yeah, the correct name is Revit 2011, isn't it?
“Learning never exhausts the mind.” — Leonardo Da Vinci
i did that but in section when i hoover it i see the slab edge and the slab .. don't they merged as one ? yes revit 2010...
Did you use the "Join Geometry" tool?
RC upstand on the edge of an RC slab |
Thu, Jul 14, 2011 at 11:04:57 AM
Revit 2010 Slab Edge Trouble |
Mon, Feb 15, 2010 at 8:54:40 AM
"Could not create Slab Edge" |
Tue, Feb 17, 2009 at 1:40:43 PM
Creating slab edge... |
Tue, Nov 4, 2008 at 3:36:03 PM
Slab edge and abc confrontation |
Wed, Dec 21, 2011 at 2:31:45 PM
Members: | 2115607 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
