51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> revit 2011 with core i5
Sat, May 15, 2010 at 1:41:06 PM | revit 2011 with core i5
jsamuelsf
How runs revit 2011 with an core i5-520m 2.40GHz (2.93Ghz Turbo Mode, 3M cache) (laptop)? It's O.K. or insuficient? I know that i7 are better (for revit and for all) but are too expensive.
 Thanks for any answer.Sorry for my english, it's very bad.
Mon, May 17, 2010 at 2:14:13 AM | revit 2011 with core i5
xzavoral
Processor is used mainly in rendering.
Core i5 is good enough, but the main issue is RAM memory, which should be at least 4 GB if you want it to be fast enough.
But if it is only for procesor decision than i5 is good enough.
PENTIUM NEW "CORE 2 DUE" (CONROE) v AMD DUAL CORE 4200
Tue, Aug 8, 2006 at 9:31:55 PM
Hid Lines deplicting finishes on walls in plan view to see the core lines only
Sat, May 15, 2010 at 5:49:20 AM
AMD DUAL CORE V INTEL DUAL CORE PROCESSORS [ 1 2 ]
Wed, Jan 25, 2006 at 2:00:11 AM
15
Revit Architecture 2011 Graphics Glitches
Fri, Aug 6, 2010 at 3:19:18 PM
Stacked Wall Core
Thu, Jan 7, 2010 at 12:55:26 PM
Page generation time: 1.7837
