36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Cannot change Project Elevation Base
Fri, May 14, 2010 at 1:46:32 PM | Cannot change Project Elevation Base
hetrick
Both the project and the shared elevation base are at 70'-6". I want my shared elevation to stay at 70'-6", but I'd like to change my project shared elevation to 0'-0". I have tried to 'Relocated this Project' when my levels are set to project elevation, but this does not change the elevation value.
This may be an easy fix, but I just cannot figure it out. I'm on a deadline, so your prompt reply would be much appreciated.
Fri, May 14, 2010 at 2:22:32 PM | Cannot change Project Elevation Base
TomDorner
4.5 Stars: 25 Votes
So why do you want to do this?  Did you model your building at 70'-6" in the Z direction using the project base of 0'-0" which by the way cannot be moved.
Doing any model movement will cause numerous headaches so need the information on what it is you are trying to accomplish.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Fri, May 14, 2010 at 4:26:04 PM | Cannot change Project Elevation Base
hetrick
I'm thinking that I must have modeled the project at 70'-6" at the very beginning and this is why it won't show as 0'-0". There is no way to make it read 0'-0" without actually moving the levels? 'Relocate this Project' only works for the shared elevation? That is bad news...
Perhaps I will just have to mask the numbers in my few elevations for now.
Fri, May 14, 2010 at 5:00:45 PM | Cannot change Project Elevation Base
TomDorner
4.5 Stars: 25 Votes
If you want your level indicators to read 0'-0" for the first floor and relative from there then:
Relocate the project down -70'-6"
Select a level marker and either duplicate it for a new type but also change the reporting of the level type to "shared" not "project"
If you created a new level type then change all the existing ones to the new one.  I typically have a shared and project based level types in my template and can intermix them as needed.
If you had counted on the shared position for linking then this method won't work as you would have need to model corectly at 0'-0" from the start or else you would need to physically move your mode down which is not recommended at this stage of your project.
The lesson learned for everyone reading this post is that you need to clearly understand Revit's positioning systems before starting a Revit model and  make sure everything is correct before you run into last minute problems where there is no simple corrective action.
Edited on: Fri, May 14, 2010 at 5:01:36 PM
Tom
Fri, May 14, 2010 at 5:09:05 PM | Cannot change Project Elevation Base
hetrick
Thank you for your reply.
Yes, lesson learned, although too late, unfortunately.
Wishlist Addition: Ability to move project easily if this simple mistake is made.
Sun, Jan 22, 2012 at 2:19:36 PM | Cannot change Project Elevation Base
nufan
I realize my answer comes a little bit late, but if anyone else out there is googling for the answer to the question of "how to change the project elevation" at a late stage in the project, then heres the solution.
In the newer versions of Revit they've introduced the "Project Base Point" and the "Survey Point".Now to change the "project elevation" you need to change to elevation of the "Project Base Point".I had a scenario where the project got started at an project elevation of 27100 mm, and then later the "Shared Elevation" was set to 27000 mm. This was fine at the time, but suddenly we needed to change the elevations to relative elevations starting at 10000 mm, without changing the actual elevation of the terrain and model.
To accomplish this I set the elevation of the "Project Base Point" to 17000 mm, and that made it work!So now if I set the levels to show the Elevation Base as "Shared", they show a value of 27000, and if I set them to show the Elevation Base as "Project", they show a value of 10000 mm.
Remember to set the clip state of the "Project Base Point" to off before changing the elevation.
Just FYI for anyone struggling with the same problem.
Edited on: Sun, Jan 22, 2012 at 2:20:48 PM
Edited on: Sun, Jan 22, 2012 at 2:27:44 PM
changing base project elevations
Mon, Jun 22, 2009 at 4:15:15 AM
topography elevation base
Tue, Mar 27, 2007 at 11:34:14 PM
Change Base Elevation
Mon, Oct 6, 2014 at 12:11:08 PM
Toposurface Elevation Base Point
Thu, Apr 28, 2016 at 4:35:51 PM
Topography Elevation from Project Base and Survey Point is Incorrect
Thu, Jan 29, 2015 at 10:32:24 PM
Page generation time: 4.9353
