Forums >> Community >> Newbies >> Structural kickers
Is it possible to draw structural kickers using revit architecture? since I'm still kind of new to Revit, can is it possible to open a structural revit model using revit architectur, and then add the kickers to it? Thanks
all Revit programs can open all Revit models as long as they are the same versions. 2010 can only open 2010 and earlier, not 2011. 2011 can only open 2011 and earlier, not 2012?
Thank you what about adding structural kickers to a revit model, using revit architecture? can it be done?
"Thank you what about adding structural kickers to a revit model, using revit architecture? can it be done?" maybe someone else can anwser that, i have no idea what that is.
anasmiley: You can add a kicker. I attached a picture of one added to my model. The kicker is a live element. It looks nice. However, when detailing kickers in sections, we would always draw them as 2D elements for our structural drawings. I would recommend that you draw them as 2D elements as popping in 3D kickers is a pain. If you are wanting to use them as 3D elements for a space and/or interference study then 3D is no problem.
I use Autodesk Revit Structure 2011 My songs: http://nkat.newgrounds.com |
Trouble Getting Angle Kickers Family to Schedule Properly |
Mon, Oct 19, 2009 at 4:04:51 PM
structural wall VS structural columns |
Tue, Apr 26, 2016 at 3:49:40 PM
Monitoring Non-Copied Structural Elements |
Wed, Jun 25, 2014 at 10:27:35 AM
Shading Structural Walls |
Mon, Nov 21, 2011 at 11:21:47 AM
Attaching Structural Col to Structural Slab |
Mon, Apr 30, 2007 at 10:05:25 PM
Members: | 2101110 | Objects: | 23173 | Forum Posts: | 152302 | Job Listings: | 3 |
