70 Users Online (69 Members):
Forums >> General Discussion >> Wishlist >> Custom Wall Cleanup tool
36 Posts No Rating |
I have an idea for an improved wall cleanup tool, this might be as a second step to the existing cleanup tool but the basic idea is you select a wall intersection like you do now with the wall cleanup tool. Then revit pulls all of the walls back away from the intersection so nothing is joined. Then it gives you a trim tool that selects each component of the wall and let you trim/extend that to any other component of one of the other walls next to it. This way you could select your gyp layer on one wall and trim/extend it to the adjacent wall, then select your mtl. stud and trim/extend it to the mtl stud in a different wall and ultimately make a true custom wall join.
0 Posts No Rating |
This is a 6 year old post! Any luck in this direction?
Nope, But HAving forgotten about the entire idea of doing this.. i'll throw it out on the revit Beta forum and see if it gets any traction.. maybe for Revit 2025 :-)
0 Posts No Rating |
http://www.revitcity.com/forums.php?action=viewthread&thread_id=32535
Oh this is the exact problem I am having. I may have to try this. I'll let you know how it goes.
0 Posts No Rating |
Thanks ArchAddict!
Make sure you thouroghly understand wall layer priorities. That may solve your frustrations.
WWHub is definitely right, having the right priorities is Key, i'd say that 95% of my wall joins are either natually correct or 1-3 variations on the wall join tool... but there is always that other 5% that require getting creative to make it come together. most of my problems arise at acute angles, or where 3+ walls come together at once. Definitely not the typical case, but frustrating when your under a deadline and you cant even get the wall to look correct.
0 Posts No Rating |
Okay, I see on the wall composition where the priorities are set up. Makes perfect sense when joined two walls with different layers. Thanks. Still a good idea up above because the wall clean ups aren't great at angles or difference wall materials.
FYI, I also resolved my issue. Just using the wall join tool, I had to click the miter button from the Butt button.  say that anywhere but here, HE-He-He!) MMMM, I think Facebook needs a Butt Button!
Okay, thanks all, great advice. Back to work!
WALL JOIN CLEANUP TOOL |
Tue, Aug 16, 2011 at 2:41:10 AM
Wall Floor Intersection Cleanup |
Thu, May 4, 2006 at 12:06:45 PM
230 brick wall wont cleanup to 250 brick veneer wall (images attached) RA2008 |
Wed, Sep 3, 2008 at 12:33:09 AM
Wall Cleanup/Join |
Tue, Jul 24, 2012 at 9:46:48 AM
wall cleanup radius |
Thu, Aug 9, 2007 at 4:56:14 PM
Members: | 2030530 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
