27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Grade Line in Elevation
Thu, May 13, 2010 at 11:10:30 AM | Grade Line in Elevation
pionkows
4.5 Stars: 2 Votes
I am having a problem with the grade projection line at the house not showing up on some stone areas on a house I'm drawing.  Does anybody have any thoughts on this?  The column shown is an architectural column with a stone material.  I also have this problem on the garage where it has a 2" stone veneer.
Thu, May 13, 2010 at 3:10:50 PM | Grade Line in Elevation
Bimman
Bimman Avatar
1 Stars: 2 Votes
i use a masking region to show my grade line.  the grade line itself (which would be the top line) is a lw 4 or thicker and the sides and bottom line are set to invisible.
PWD
Grade Hatch in Elevation
Wed, Aug 6, 2008 at 12:03:17 AM
Grade Lines in Elevation view not showing
Fri, May 25, 2007 at 5:49:37 PM
show grade line not topo mass
Wed, Feb 8, 2006 at 9:19:36 AM
grade line
Wed, Feb 8, 2006 at 11:23:56 AM
invisibility below grade
Fri, Jun 29, 2007 at 9:38:07 AM
12
Page generation time: 0.6676
