130 Users Online (128 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> monolithic stairs
Thu, May 13, 2010 at 10:34:56 AM | monolithic stairs
nojin
does anyone know how to change the slab thickness on a monolithic stair on revit structure 2010?
Thu, May 13, 2010 at 10:44:03 AM | monolithic stairs
4 Stars: 203 Votes
I don't work in Structural but try to change the "Tread Thickness".....
Thu, May 13, 2010 at 12:54:18 PM | monolithic stairs
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
try the various thicknesses, stringer thickness I think
Fri, May 14, 2010 at 11:13:50 AM | monolithic stairs
pdoug
3 Stars: 2 Votes
I tried modeling monolithic stairs using the stairs tool, but with limited success.  I am sure it can be done, but I was having difficulty creating a riser profile to suit what I needed.  What I ended up doing instead was creating an in-place family which in the end was much easier to work with for what I needed.
Sat, May 15, 2010 at 6:00:37 AM | monolithic stairs
4 Stars: 203 Votes
You never ask about Risers in a monolithic stair, your first question was and I quote "does anyone know how to change the slab thickness on a monolithic stair on revit structure 2010, if you ask about risers in a monolithic stair we had told you need to create that in a in-place family with a categorie "generic Model" because in-place don't have "Stairs" in his categories..
Sat, May 15, 2010 at 8:55:53 PM | Typhoon
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Quoting Typhoon from 2010-05-15 06:00:36
Ty, the first question was not made by pdoug but by nojin.....Puh
Sun, May 16, 2010 at 6:33:13 AM | monolithic stairs
4 Stars: 203 Votes
OMG.... I had not noticed.. sorry Nojin...
Can't create monolithic stairs (Revit 2013, beginner)
Fri, May 27, 2016 at 11:21:57 AM
monolithic stairs
Thu, Mar 15, 2012 at 11:34:59 PM
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:03 PM
Monolithic stair PROBLEM
Sat, Feb 9, 2013 at 8:14:33 AM
Revit Monolithic Stair with Material Finishes
Tue, Apr 14, 2015 at 6:00:27 AM
Page generation time: 2.3170
