52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Concrete Beams with Toe
Thu, May 13, 2010 at 6:49:27 AM | Concrete Beams with Toe
AJBuckley
Hi Guys,
Forgive me as I'm a complete Revit Newbie and this is the first project I've used Revit on.
I Need to create a Ground beam with a toe on it to support some facing brickwork... does anyone have a family they've made up already or point me in the direction of a tutorial? Was going to model the toe as a seperate beam running next to the main footing but thought this defeats the point a bit! bottom of the beam and toe need to be flush and ideally the width and depth of the toe should be adjustable independently from the main beam dimensions.
I'm assuming it's not overly complicated but I don't have time on this project to play with the family creation and editing tools Sad
 Oh and I'm in the uk so metric would be preferred Smile
Cheers and much appreciated
Ad.
Thu, May 13, 2010 at 7:00:07 AM | Concrete Beams with Toe
AJBuckley
Forgot to add that it's concrete... I tried modifying the standard concrete rectangular beam profile but but failed and don't have the time to play with it like I said before.
Cheers :D
Thu, May 13, 2010 at 10:31:46 AM | Concrete Beams with Toe
TKennedy
4 Stars: 7 Votes
Try using a foundation wall and add a wall footing. There is a footing available already with a toe on it.
Concrete Columns and Beams cuts through wall...
Mon, Feb 4, 2013 at 8:10:15 AM
Concrete columns behaviour before and after placing concrete beams
Tue, Apr 1, 2014 at 1:58:43 AM
Concrete Beams
Tue, Nov 11, 2008 at 3:33:21 PM
Auto Join Concrete Column & Beams
Thu, Jul 1, 2010 at 2:08:30 AM
structural concrete beams into wall
Wed, Aug 18, 2010 at 2:02:56 PM
Page generation time: 0.3981
