40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Floor+beam and wall joints
Wed, May 12, 2010 at 10:46:57 PM | Floor+beam and wall joints
brunopicinini
Hello,
I am having some issues regarding the joints of wall + beam + floor in my sections.
Please check the attached section png, it should be clear what is the problem.
3. Any walls that go multiple stories should go multi stories not stop and start at each floor.
I have read this tip in another topic, but maybe that is old now. The problem in doing that is that my sections won't show up as I'd expected them to. I would like to have only my floor+beam joined showing as a single object and the walls NOT going through them.
 I believe that I should model in Revit as it is in the real world, so that would make me make one wall for each level, but then, say I have 100 walls in one floor, only 10 of them will have a different top constraint. Will I have to setup these 10 walls manually?
Thanks,
Beam system height VS. Beam height error
Fri, Jan 22, 2016 at 4:31:21 PM
vertical joints in hosted wall sweep?
Mon, Aug 13, 2007 at 3:37:16 PM
Wall and floor joints
Tue, Dec 30, 2008 at 10:42:09 AM
13
Beam and block floor problem - cut into wall?
Fri, Nov 30, 2007 at 3:05:03 AM
Cutouts in wall and floor joints
Tue, Dec 30, 2008 at 11:46:32 AM
Page generation time: 1.5470
