33 Users Online (32 Members):
Forums >> Revit Building >> Technical Support >> Revit Section Callouts Misbehaving
5 Posts No Rating |
Hello, I am using Revit Architecture 2010. I have a been working on a project for quite some time, and during the process I was asked to re-order some of the sections on a sheet file. Since then, all of the drawing numbers on the sheet file are correct, but NONE of the Section heads in the plans and elevaitons are behaving properly. Has anyone else experienced this, and is there a way to correct it? I've already tried going back and overwriting things so that all the numbers match up, but the next time I save it seems that the problem pops right back up. This has never been a problem in our other project files... Thanks!
<>blame the monkeys, <>j100 <> |
![Bimman Avatar](user_avatar/938.jpg)
![1 Stars: 2 Votes](/images/stars_1.gif) |
were any of the calloutsa that are not working referenced from another view. if so they may be still referencing the number they originally came from.
----------------------------------- PWD |
5 Posts No Rating |
Thank you for the response. As far as I can tell the callouts were not referenced from another view. The section head on the plans simply does not match the actual number that the section is given on the sheet file. As best I can tell, the numbers are re-writing to the original order in which the sections were created, even if their section names have since been changed as a part of my quest to fix this error.
I have not heard of any problems like this so I suspect that the two items are not the same. No use guessing at this. Open the view from the callout and look at it's properties. It will tell you what sheet it is placed on.
multiple section callouts |
Wed, Jun 4, 2008 at 9:04:18 AM
Are Callouts Vew Specific? |
Wed, May 12, 2010 at 3:56:06 PM
Section Callouts Dissapear w/Level Change |
Tue, Aug 19, 2008 at 1:45:27 PM
Revit 2008 - Callouts not appearing in wall section |
Thu, May 31, 2007 at 3:48:57 AM
Edited profiles in section do not appear in callouts |
Tue, Jun 10, 2008 at 3:53:11 PM
Members: | 2017914 | Objects: | 22948 | Forum Posts: | 152215 | Job Listings: | 3 |
