54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wind Bracing Attachment
Wed, May 12, 2010 at 7:21:53 AM | Wind Bracing Attachment
Altruant
Hi,
I have set up the framing elevations and am currently putting the wind bracing in.
However i am finding it very annoying how the braces are practically floating in mid air/digging through beams depending on the orientation of the columns. Is there a way to fix this so they attach properly?
I have attached images below
Thank you for any help.
Thu, May 13, 2010 at 2:53:36 AM | Wind Bracing Attachment
Kardiff
5 Stars: 3 Votes
Edit the family so at the angle you are placing them, they cut vertically,Then if you set it as your first image beam orientation they'll appear attached
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Wind bracing panels
Wed, May 27, 2009 at 5:43:17 PM
Vertical bracing symbolic line ???
Tue, Jun 4, 2013 at 7:33:51 AM
Savonius wind turbine
Fri, Apr 9, 2010 at 3:55:22 PM
Bracing Shedules
Thu, Aug 27, 2009 at 2:53:26 AM
New Project
Wed, Oct 27, 2004 at 9:09:09 PM
Page generation time: 0.2026
