62 Users Online (60 Members):
Forums >> Revit Structure >> Technical Support >> demo wall
![Bimman Avatar](user_avatar/938.jpg)
![1 Stars: 2 Votes](/images/stars_1.gif) |
is it possible to demo say half of an existing wall or to i need to make two differrent walls representing both parts of the total wall and then demo the part that is going away. also if i do that, windows and doors only cut one wall so do i then need to place an opening at each instance where they occur or is there another way to do this. thanks for listening,
----------------------------------- PWD |
Just split the wall where you need to and demo the part you don't want. If you are splitting it horizontally and demoing the upper half, then doors and windows can be hosted in the lower half and they will cut into a new wall placed in the upper half. You may have to use join geometry.
Demo Door Automatic new wall |
Thu, Oct 4, 2007 at 10:20:29 AM
Demo door, make cased opening, no fill in wall |
Fri, Mar 23, 2012 at 12:34:24 PM
Demo Door/New Wall |
Wed, Dec 14, 2005 at 12:56:27 PM
No demo lines with new door in existing wall |
Thu, May 7, 2009 at 2:24:45 PM
Room/area tags on floor plan with demo'd wall |
Tue, Feb 10, 2009 at 9:53:41 AM
Members: | 2022524 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
