Forums >> Revit Building >> Technical Support >> Hip Board
44 Posts No Rating |
Is there a good way to do hip/valley boards?
Sam
Post edited on 2005-09-27 14:24:10
not quite sure what you are asking... are you talking roofs? use the roof tool and the define slop.
using the roof tool does not mean it has to be a roof... with different materials you can create what ever you want
Two methods:
using hosted sweep fascia profiles and applying the valley/hip profile the appropriate edge of the roof, (you'll have issues where they are three merging into each other and getting them to clean up properly.)
The method i typically use is to copy the roof up in elevation to sit on top of your current roof. Change it to a type that has a small thickness to represent the capping, then use the opening tool to cut our the unwanted sections of the roof.
HTH.
Sorry for bad Symantec�s. Meant rafter, not board.
Mr. Spot,
Thanks for the reply. Fascia Profile does work for quick and dirty as you mentioned. You completely lost me on the second one.
I think I�ve concluded that roof framing members are quicker in 2D. At least one user agrees with me over at the AutoDesk Group. I prefer to model residential floor structure members however.
Sam
was interested in the hip and ridge flashing discussion - we use the hosted sweep option all over rooves, and attempt junction clean ups if it looks a bit odd. love the ability to change mitreing options at sweep ends. clever idea of mr spot's to add a roof slightly above though - might try that!
but how do you create a real looking valley? ideally a void sweep would do it, but no such thing i think. i guess i will have to use mr spot's idea in combination with 3 roof pieces! or maybe do not worry about it and got on with the job.
Another option would be to change the roof to sloped glazing then apply a specially created corner mullion for the ridges/valleys. Then its just a simple matter of create a new panel with the appropriate roof material.
Of course there is such thing as a void sweep... If its absolutely vital to clean up the host sweeps you can do so manually using an in-place family and cutting the host sweeps in the appropriate locations to have them mitre neatly...
Partial Hip Roof |
Tue, Jun 26, 2007 at 3:22:10 PM
Problem aligning hip rafter on hip roof exactly where i want it. RAC 2009 |
Tue, Feb 10, 2009 at 6:37:31 PM
Roof hip with different height fascia |
Mon, Sep 9, 2013 at 2:25:27 PM
Hip Roof Issue |
Mon, Mar 24, 2008 at 1:30:08 PM
Can't get Gable roof to Join Hip roof |
Wed, Aug 20, 2014 at 3:56:33 PM
Members: | 2119063 | Objects: | 23205 | Forum Posts: | 152311 | Job Listings: | 3 |
