33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> text box leader alignment
Sat, May 8, 2010 at 8:35:17 PM | text box leader alignment
ICON1962
I was always under the impression that the size of the text box is somehow defaulted to fit around the text defined by system parameters.
the attached image might suggest otherwise.  aside from line weight, both highlighted text elements have identical parameters in the "type properties" box.
 why is one box bigger that the other.
 each box allows for only line of text.
Sun, May 9, 2010 at 5:23:15 AM | text box leader alignment
4 Stars: 202 Votes
What "the attached image might suggest otherwise" ???
Sun, May 9, 2010 at 7:48:45 AM | text box leader alignment
coreed
coreed Avatar
4 Stars: 16 Votes
as Typhoon said what "attached image". we were under the impreession that their was an attached image. there could be many reasons why it is not attached. as for text, when you are starting to place text and just click to define a starting point, not dragging to define a text box, the text box should default to fit around the text entered. is this problem happening when you are placing text?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Distance from leader to text... Revit 2010
Tue, Jun 1, 2010 at 9:13:52 AM
keynote text and leader alignment
Thu, Aug 19, 2010 at 8:56:11 AM
Multiple Leader Text
Sun, Nov 18, 2007 at 12:33:41 PM
CHANGING SIZE OF DIMENSION TEXT BOX
Wed, Feb 25, 2009 at 4:22:18 AM
ARC LEADER NO TEXT
Thu, May 2, 2013 at 10:36:05 AM
Page generation time: 1.0016
