86 Users Online (85 Members):
Forums >> Revit Building >> Technical Support >> Doors interfering with each other between phases
20 Posts No Rating |
I am new to Revit and am working on my first project. I have phasing set up but am having problems with new doors and demo'd doors interfering with each other. We are demo'ing an old door and replacing it with a larger new door. When I go to place the new door I get an error and either can't place the new door or I have to delete the old door. This seems like a a major flaw in the phasing system and can't believe that there isn't a way to do it. I have looked through the Revit help file, AutoDesk's Knowledge Base, and RevitCity forums but can't find anything. Any help would be appreciated.
The problem is probably caused by revit wanting to fill in the demo'd opening and your new door wanting to remove that. I think Revit does need an option to just remove a door / window and not fill in the opening. I have not run across this problem but I could get around it visually by using design options.
Phases and Schedules |
Thu, Aug 26, 2010 at 1:31:11 PM
Phasing is interfering with Room Area/Tags (I think) |
Wed, Sep 28, 2016 at 1:15:48 PM
2020 revit - doors not recognizing rooms in a phased project |
Thu, Feb 13, 2020 at 9:52:26 AM
Capabilities to isolate phases |
Tue, Nov 28, 2006 at 5:43:02 AM
Demo Plan with multi phases |
Tue, Jul 28, 2015 at 7:34:43 AM
Members: | 2056445 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
