Forums >> Revit Systems >> Technical Support >> TOPOSURFACE
33 Posts No Rating |
I'm struggling..can someone direct me to a video on simply toposurace. i've done my contours but now i need to get it graded for basement, crawlspace and garage sog. help
----------------------------------- IMAC 3.06GHZ,MACOSX 10.5.6 with WINDOW XP PROF, REVIT ARCH 2009,AUTOCAD 2009,VECTORWORKS 11.0,ARCHICAD 7.0,LEED AP. |
Can you elaborate your question please? "i've done my contours but now i need to get it graded for basement" You have done your Contour in what software? Revit? Civil?? How? Do you want to create a PAD to create a "Basement" in your building???
Thanks Typhoon. I'm using Revit Architecture 2009. I've done the contours using the points [yes, I have the z calculated for each point]. Because the house is on a slope, I have started with created levels - basment level, crawlspace , ground level top of wall and roof level. I've drawn the foundation walls with bearing footings and slab using the Structural/Foundation wall and slab tool. Through thi sprocess, i find it really time consuming but I tried to do it as if I am building from ground up. I don't seem to be able to do it from plan so I use the section tools to help me to move the slab and foundation wall. I don't know if there is a faster and smarter wall of doing that. Also, I don't udnerstand what is the pad, sub region different from each other and how is that different from the slab. I wish there is a video tutorials on toposuface so I can learn. Lilian
I gonna create a video for you because i think an Image worth more than a 1000 words... BUT you must use your HELP menu and the Tutorials to learn more about this.... Ok, watch this: http://www.megaupload.com/?d=2CMH8TS3
Edited on: Sat, May 8, 2010 at 8:10:19 AM
The link is suspended Ty
Not Sure What Revit Can Do?... Find it OUT!!!
“Imagination is more important than knowledge...” -Albert Einstein |
it's working, try it again...
Nevermind it worked at the end
Thanks Typhoon. I've downloaded the file PAD.rar but what's application is that? I can't open in quick time, media, etc. Lilian
USe internet explorer or firefox for the other format swf I think or flv you guess
" I can't open in quick time, media, etc."....weird, I could open that .mp4 file using WMP, VLC, Quick Time & Real Player. The other file (.swf), is the same video but you can open it with Flash Player or Haihaisoft Universal Player.....
Edited on: Sat, May 8, 2010 at 10:12:05 PM
Flat Toposurface |
Thu, Aug 3, 2017 at 8:58:50 AM
Toposurface&subregion problems |
Thu, Apr 16, 2009 at 1:47:07 AM
Toposurface in Elevations |
Thu, Aug 27, 2009 at 1:51:07 AM
what is the easy to do toposurface |
Mon, Feb 27, 2006 at 8:44:08 AM
14
Toposurface |
Tue, May 11, 2010 at 9:04:46 AM
Members: | 2116546 | Objects: | 23196 | Forum Posts: | 152303 | Job Listings: | 3 |
