Forums >> Community >> The Studio >> printing mass elements
does anybody know why everytime i want to print a mass (with materials assigned to it) that i created in a project It prints all the hidden lines also instead of printing as a solid mass?
am i missing something here ???
thanks for the help
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
make sure mass visibility is check in the view with the visibility setting, are you shaded view or hidden line?
1 Posts No Rating |
A couple of things come to mind -
- make sure that the view is not set to visibility -> shading with lines
- make sure that your material doesn't have any transparency to it (in the material editor) otherwise the lines on the back faces of a 3D object will show through the transparent mass. see Extrusion Properties -> Materials & Finishes --> Transparency
Post edited on 2005-09-27 22:19:27
17 Posts No Rating |
I recently posted a similar question to the original of this thread, but got no response. Perhaps because it was too similar to this earlier question.
Unfortunately, the replies here didn't help. My visibility is "hidden line" and transparency for the material is set at "0". It looks right on screen, but everything shows through. All other objects, (walls, doors, etc.) print/plot correctly.
Here's the text of the original post:
I have several masses with a stone pattern assigned to the surfaces. In the 3-D views I've created, everything looks fine. When I print though, I can see through them as though the view setting is set to "wireframe" even though it isn't. Also, all other objects print correctly - even those that have the same pattern/material assigned to the faces.
I'm using Revit 8.1
Thanks,
Zak
10 Posts No Rating |
I am having the same problem - Mass object looks fine on the screen but will always print as if it's transparent. All visibility settings are "correct", the extrusion of the mass has the Default Wall material assigned with transparancy set to 0. I cannot "convert face to wall" becauxe the geometry does not work out. Very frustrating! Hope someone understands and has a proper answer.
![4 Stars: 4 Votes](/images/stars_4.gif) |
check the print raster image checkbox in print settings, and you will get your mass.
1 Posts No Rating |
check box before printing > see attachment
See thread: http://www.revitcity.com/forums.php?action=viewthread&thread_id=8482 Masses always print transparent. Make generic models instead. On the Modeling tab, choose Create. You may of course choose to assign a proper category instead of the Generic Model category if one applies. Then visibility can be controlled through the Visibility/Graphics control as usual. Unfortunately, I don't think that you can convert a mass that you've already made into a model. Instead, you will need to delete what you have. If it's an extrusion you can edit the mass, copy the sketch lines and then paste same into the model sketch. That may save some steps if the extrusion sketch is complicated.
Try this one at http://www.digiteksf.com/canvas-prints-2/ you can get several ideas about printing in mass elements.
Newbie - Need help with mass elements |
Mon, Feb 8, 2010 at 1:11:14 PM
Massing printing problems |
Tue, Feb 9, 2010 at 8:11:10 AM
Mass Object Not Printing Correctly |
Thu, Feb 28, 2008 at 2:19:56 PM
recognize solid imported objects as mass elements... |
Tue, Jan 20, 2009 at 10:26:33 AM
Massing Printing Problem-solve (sort of)-Revit Architecture (2008) |
Fri, Aug 24, 2007 at 3:15:20 PM
Members: | 2022332 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
