Forums >> Revit Building >> Technical Support >> Cut Plane display issue
44 Posts No Rating |
I am having problems w/ a wall showing the proper hatching at the cut plane location. I have the cut plane at 3' above the level and I have a 4'-8" wall. If the wall is change to at least 5'-9" then the hatching shows correctly for just a masonry wall. If I have the wall at 4'-8" I get a shaded wall with no hatching. If I put the cut plane at 6' it shown correctly as being above the all w/ no cut. With the cut plane at 3' it shows the wall being cut (just shaded no hatching). I cannot figure out what is going on. This seems to be true of any wall that is greater than the 5'-9" showing the hatching and less than 5'-9" not showing the hatching. Seems like it is a cut plane issue in the view properties but I can't seem to solve it.
any wall in revit that has an "unconnected" height of less than 6'-0"will only shown in projection. that is "unconnected height", not connected height.
Edited on: Thu, May 6, 2010 at 5:43:28 PM
trhymans try the "Plan Region" tool....
41 Posts No Rating |
"any wall in revit that has an "unconnected" height of less than 6'-0"will only shown in projection. that is "unconnected height", not connected height."
Any way to change this in Revit 2011? I have a wall less than 6' that I need to show as cut and can't attach to a floor above because it's offset from the edge of the floor (outwards).
Try this. Make the wall tall enough to show correctly, then edit the wall profile reducing it to the height you want. Now it should show correctly.
Watch this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=20945
View range queations |
Mon, Jan 18, 2010 at 4:48:18 PM
Displaying windows above cut plane |
Mon, Oct 27, 2014 at 2:39:25 AM
How to control where the cut plane is for families? |
Sun, Nov 22, 2009 at 10:20:00 AM
Elevation's primary cut plane disappered and no grips |
Tue, Apr 10, 2012 at 11:49:00 AM
Controlling how stuff deplays beyond bottom cut plane |
Thu, Mar 27, 2008 at 12:47:32 PM
Members: | 2101738 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
