22 Users Online (21 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Shaft demolision
Thu, May 6, 2010 at 3:46:50 PM | Shaft demolition
kennybmiller
I am working on the remodel of an existing building in which we are removing the walls on the upper 2 floors of a 3 story elevator shaft and infilling the floor openings but leaving the existing CMU/gyp. shaft walls in place on the first floor.  I have constructed the shaft in the existing phase using a curtainwall with curtain grids separating the different wall types on each floor.  The problem is when I demolish the wall on the upper level it demos the wall on every level.
Is there a way to specify which levels to demolish and which to leave in place on a curtainwall.  Or should I have constructed the wall differently, possibly a stacked wall?
Thanks for any suggestions
Edited on: Thu, May 6, 2010 at 3:49:09 PM
shaft cutting beams
Tue, Jun 2, 2009 at 7:47:18 AM
A Floor That Can't Be Penetrated by Shaft Opening
Thu, Feb 20, 2014 at 2:30:48 PM
Shaft Problem
Thu, Jul 12, 2012 at 5:20:52 PM
Shaft Visibillity
Wed, Jun 1, 2011 at 10:47:37 AM
Visible shaft in 3D view
Tue, Aug 10, 2010 at 8:02:51 AM
Page generation time: 0.4625
