21 Users Online (20 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Detail Lines in Brackets?
Thu, May 6, 2010 at 10:07:24 AM | Detail Lines in Brackets?
treeves1968
I have noticed that when I go to do a detai line, in the list some of the linetypes are in brackets "<>" and some of them arent. What do the brackets mean?
Thu, May 6, 2010 at 12:38:47 PM | Detail Lines in Brackets?
TomDorner
4.5 Stars: 25 Votes
The ones in brackets are system lines that cannot be deleted.  There are however a few more system line that don't show up in the brackets.  Go to the Line Styles dialog box, highlight a Line Style and if the "delete" button doesn't highlight it is a system line that you cannot delete.
A good template technique is to define your own standard Line Styles.  Many firms do so by a preceding number that indicates line weight and so the lines are presented in ascending order. Like:
1 - Thin Lines
2 - Medium Lines
3 - Med. Heavy Lines
4- Heavy Lines
etc.
The trick to all this though is to make sure that not only your template includes all your new line styles, but all the families you create use the same line styles.  If you don't coordinate between project and families, then when families are loaded with different line styles, those family line styles become part of your project lines styles.  If you use families OTB from Revit or downloaded from site like this one you are at the mercy of who created them unless you normalize the line styles for your standards.
HTH
Tom
Cantilevered roof cable an brackets
Fri, Oct 24, 2008 at 3:51:55 AM
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:23 PM
detail lines
Mon, Jan 23, 2006 at 4:10:30 PM
Model Lines to Detail Lines???
Sun, Aug 31, 2008 at 9:24:50 PM
call outs and detail lines best practices?
Tue, Dec 15, 2009 at 8:46:41 AM
Page generation time: 0.5669
