133 Users Online (131 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> I Can't use RPC content in Revit Architecture 2011
Tue, May 4, 2010 at 4:00:47 AM | I Can't use RPC content in Revit Architecture 2011
ArkitectJM
ArkitectJM Avatar
3.5 Stars: 5 Votes
I Can't use RPC content in Revit Architecture 2011. (only the one who comes with the software)
Everytime I try the program freezes. Do you know a turnaround?
:_
Tue, May 4, 2010 at 4:43:14 AM | I Can't use RPC content in Revit Architecture 2011
4 Stars: 202 Votes
Did you see this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=20232
Tue, May 4, 2010 at 6:03:47 AM | I Can't use RPC content in Revit Architecture 2011
ArkitectJM
ArkitectJM Avatar
3.5 Stars: 5 Votes
Thank you Typhoon.
Yes I saw that but when I try to change the path.. the program freezes again..
so I need to go back to the original RPCs file..
Tue, May 4, 2010 at 10:39:51 AM | I Can't use RPC content in Revit Architecture 2011
ArkitectJM
ArkitectJM Avatar
3.5 Stars: 5 Votes
I just received this email from Archvision:
Hello ArkitectJM,
This is a bug that we are working with Autodesk to fix.  Apparently their latest implementation causes Revit to hang if you have too many RPCs in the path of your ACM.  Try changing your ACM’s path to point to a folder with only a couple hundred RPCs and your Revit should open up just fine.  Hopefully Autodesk will have this fixed soon.  My sincere apologies.
Please contact me if you have any questions and I will gladly assist.
Sincerely,
Jon Anderson
Customer Service Manager
ArchVision
163 East Main Street, Suite 310
Lexington, Kentucky 40507
USA
859.252.3118 ext. 103
859.381.1108
support@archvision.com
www.archvision.com
Wed, May 5, 2010 at 10:20:39 AM | I Can't use RPC content in Revit Architecture 2011
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
Arki: I am having the same problem. Did not know how to fix it any help i ll appreciate Thanks!
Not Sure What Revit Can Do?... Find it OUT!!!
Imagination is more important than knowledge...” -Albert Einstein
Thu, May 6, 2010 at 2:55:35 AM | I Can't use RPC content in Revit Architecture 2011
ArkitectJM
ArkitectJM Avatar
3.5 Stars: 5 Votes
Carrucha75.    Yes, I think you have to follow the instructions that Typhoon showed before:
maybe you need to change the path of the ACM, or download and instal the latest ACM from Archvision.
Smile
Edited on: Thu, May 27, 2010 at 4:47:22 AM
Fri, Jun 4, 2010 at 9:46:21 AM | I Can't use RPC content in Revit Architecture 2011
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
i did not have success on fixing this problem may i ll wait until there is another person with the same error message.
Looking for RPC content
Sun, Mar 15, 2009 at 8:14:01 AM
Revit 2009 - RPC's
Thu, Sep 9, 2010 at 3:16:35 PM
Revit 2009 - RPC Archvision Content
Tue, Jan 6, 2009 at 10:46:30 AM
How can we import rpc files into Revit Architecture 2011???
Fri, Apr 13, 2012 at 4:30:14 PM
Non-ArchVision RPC Content
Thu, Dec 29, 2011 at 8:21:56 AM
Page generation time: 1.7298
