58 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> Exterior Render-Interior too dark!!
2 Posts No Rating |
I had tried to render an exterior of a building, but the outcome of the interior is always dark. Although I had tried to put in more windows around the wall faces, the interior still lack of DAYLIGHT. Beside adding in artificial light (which I am not really wanting to due to slow rendering) or adjust the exposure of the rendered image, is there any other way to make the interior brighter? Thnx a lot for any help~
Did you try to change the lighting scheme from exterior sun only to interior sun only? This should help some, I just dont do many renderings these days with no interior lights. good luck
11 Posts No Rating |
After you save the original rendering, lighten the entire image (either with Revit exposure tools or in Photoshop) in a duplicate file. Then you can cut and paste in Photoshop the lighter interior to the correct-exposed exterior. This is actually a technique used by good architectural photographers to correct dynamic range limitations. There is also software available for automatic blending of photos with higher and lower exposures, but the manual option should work fine for you.
2 Posts No Rating |
Yea, thats the way i did right now, but i wonder if there are any other way instead of adding interior light or enhancing in photoshop...anyway, thanks a lot guys~!
Render exterior view with artificial lights - how to make interior glow? |
Sun, Mar 11, 2012 at 12:45:28 PM
Interior Lighting from an exterior view |
Wed, Nov 11, 2009 at 12:41:44 PM
Basic Rendering Question |
Sun, Aug 6, 2006 at 11:51:18 AM
Interior Lighting Render Problem |
Mon, Jan 31, 2011 at 12:49:05 PM
Rendered Interiors but completely dark with added light fixtures |
Fri, Oct 29, 2010 at 2:18:06 PM
Members: | 2017191 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
