52 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Urgent! Splitting and moving viewports
Sun, May 2, 2010 at 8:20:41 PM | Urgent! Splitting and moving viewports
juliaratsa
Hi, I have a landscape format sheet 24 x 36.  I must place a wall section on it of 1"= 1'-0" scale.  The section is too tall and does not fully fit.  I have split the section in 2 places and moved them closer together (vertically shrunk the section).  I now have 3 small separate parts of the wall.  They still do not fit onto the sheet vertically.  Is there a way to grab one split part and horizontally move it to the side from the other parts? Thanks!
Sun, May 2, 2010 at 8:29:06 PM | Urgent! Splitting and moving viewports
juliaratsa
This is Revit Architecture 2009
Mon, May 3, 2010 at 4:26:37 AM | Urgent! Splitting and moving viewports
4 Stars: 203 Votes
Hi, what you can do is Duplicate that section view in 2 or 3 views, (rename them to "i.e. Section A_TOP", Section A_BOTTOM"Winking adjust the crop view like you want in any of those views then drag to the sheet like you want.
Moving Viewports
Fri, Mar 22, 2013 at 12:06:05 PM
Edit Visibility Graphics in multiple viewports?
Mon, Nov 28, 2011 at 1:37:06 PM
Viewports orginizing on sheet
Mon, Apr 18, 2016 at 10:45:15 AM
Room Plans, Non Rectangular viewports from Revit 2014 and Python Shell
Thu, May 23, 2013 at 2:28:20 PM
many viewports
Mon, Aug 24, 2009 at 9:17:13 AM
Page generation time: 1.1560
