74 Users Online (73 Members):
Forums >> Community >> Newbies >> How to change the number size on the tape tool and on the cursoe
1 Posts No Rating |
Hello, im new to revit andi cannot find away to change the number size height on mt tape measure tool and when i am creating a wall. When i create a wall the numeric numbers are too small i would like to make them bigger.
You don't said what version of Revit are you working... In 2011 you change them in the "Options" like you can see in the image attached... In 2010 you must follow this: - Open Revit.ini file in Notepad. The file is typically located in C:\Program Files\Revit Structure 2008\Program.
- Add the following line to Revit.ini in [Graphics] section:
TempDimFontSizeInPoints=N Where N is a number larger than 8 (default hardcoded value). Good starting point is twice the default size (i.e. 16-17). - Save Revit.ini.
- Restart Revit. If the size of temporary dimensions is still small, repeat from step 1 with larger number.
Please note, the [Graphics] section may not exist. If this is the case add a line that contains [Graphics]. here you have the original post: http://bimandbeam.typepad.com/bim_beam/2007/08/how-to-adjust-t.html
Edited on: Sat, May 1, 2010 at 4:47:10 AM
tape measure tool doesnt work in elevation |
Wed, Jan 12, 2011 at 1:19:04 PM
dimension number size |
Wed, Apr 7, 2010 at 3:39:05 PM
Tape Measure Properties [ 1 2 ] |
Thu, Aug 21, 2014 at 12:15:12 PM
18
HOW TO CHANGE GRID CIRCLE AND THE NUMBER SIZE? |
Sun, Aug 2, 2009 at 9:30:47 AM
SF Inquiry tool like in Acad?? |
Wed, Jul 23, 2008 at 8:40:47 AM
Members: | 2085015 | Objects: | 23131 | Forum Posts: | 152277 | Job Listings: | 3 |
