112 Users Online (110 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Quick Access Toolbar 2011 losing tools on startup
Thu, Apr 29, 2010 at 5:24:13 PM | Quick Access Toolbar 2011 losing tools on startup
latemore
latemore Avatar
3 Stars: 2 Votes
Hi all
started using 2011 this week - great so far.  but every time i load revit, it removes many tools from the quick access toolbar, that i have added.  is anyone else finding this?  is there a limit to the number of tools it can take?
thanks in advance.
Tue, May 11, 2010 at 8:46:08 AM | Quick Access Toolbar 2011 losing tools on startup
kdummer
This has been happening to me too.  Anyone know of a fix?
Tue, Jun 1, 2010 at 10:17:46 AM | Quick Access Toolbar 2011 losing tools on startup
twogunjack
It is happening to me too.  I have also noticed some tools that have dissappeared won't let you R click and add them back; i.e. "Add To Quick Access Toolbar" is grayed out even though the tool is not showing up on the QAT.
Wed, Jun 2, 2010 at 2:34:50 PM | Quick Access Toolbar 2011 losing tools on startup
ehoff
I likewise am loosing the quick access tools that I have added (revit 2011).  At first I thought it was due to a power failure/incorrect shutdown, but it seems that a regular startup also leads to missing tools.
Wed, Aug 18, 2010 at 10:24:18 AM | Quick Access Toolbar 2011 losing tools on startup
Thread Post Kudo! #5
hinzec
This is for 2010 MEP hope it works for 2011
Go to the link below it will explain the process. You need to open revit setup your QAT the way you want it. Find the UIState.dat file. In windows 7 look here C:\Users\YOUR NAME\AppData\Local\Autodesk\Revit\Autodesk Revit MEP 2010. Delete it and close revit, it will create a new one with your custom QAT saved in it. Restart revit your QAT sould be the way it was the last time you closed revit.
 Go to this link to read more http://archin3d.blogspot.com/2009/04/boston-revit-users-group.html
Edited on: Wed, Aug 18, 2010 at 11:04:48 AM
Wed, Aug 18, 2010 at 4:50:32 PM | Quick Access Toolbar 2011 losing tools on startup
latemore
latemore Avatar
3 Stars: 2 Votes
thanks for that hinzec
i had given up trying to fix the QAT.
so now, i added tools to it.  closed down, opened, and repeated it.  the QAT is holding now.  this might be because of the patch a couple of months ago!
Thu, Aug 19, 2010 at 6:37:57 AM | Quick Access Toolbar 2011 losing tools on startup
bdbhoy
1 Stars: 1 Votes
Just upgraded to RAC2011 and its happening to me too, (didn't have this problem in RAC2010).  Don't understand or want to mess about with solution above.  Can the QAT be saved in the main menu?
Thu, Aug 19, 2010 at 6:43:53 AM | Quick Access Toolbar 2011 losing tools on startup
latemore
latemore Avatar
3 Stars: 2 Votes
i suggest you get the latest patch.
go to autodesk subscription centre and download the latest one.  it seemed to work for us.
Print Icon on Quick Access Toolbar
Wed, Oct 29, 2014 at 6:27:05 AM
Missing info on Quick Access Toolbar v.2010
Fri, Sep 11, 2009 at 12:56:22 PM
Fri, Oct 4, 2013 at 8:26:23 AM
Mirror about manual axis in 2010??
Fri, May 1, 2009 at 1:26:16 PM
Troubles with Revit 2013 display and quick access tools on Win8/nVidia 670mx
Mon, Mar 25, 2013 at 3:48:11 PM
Page generation time: 0.6018
