34 Users Online (33 Members):
Forums >> Revit Building >> Technical Support >> curved stair
39 Posts No Rating |
I need some help drawing this curved stair (2009) attached are 2 images" the first is how it looks when I draw it in plan (not that when I drew it as a straight stair it worked, the problem was when I drew the risers as arcs) The second image is what it looks like in 3D view. any help is much appreciated. Thanks
I create this video few months ago but the issue is the same... Watch the video: http://www.megaupload.com/?d=5SI8K6ZO and here you have the original thread: http://www.revitcity.com/forums.php
Edited on: Thu, Aug 12, 2010 at 3:25:47 PM
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
In addition to Typoon's fine video, you could sketch the stair as one straight stair then add the curved treads and move the boundry. See attached file for example. Another option is to do an in-place family that is a sweep and skip using the stair tool all together. HTH
thank you so much! it makes no sense to me, but it works. you are a life saver!
The problem here it's only with "Monolithic Stairs" because the others work greats....
Curved Stair Question |
Mon, May 7, 2007 at 2:10:41 PM
Stair has strange curved underside |
Thu, Aug 31, 2017 at 9:16:25 AM
Curved Stair higher than 4m |
Wed, Jun 3, 2009 at 11:15:02 AM
90 Degree Curved Stair possible?? |
Thu, Apr 3, 2008 at 6:54:31 PM
Curved monolitic stair won't generate in 3d |
Tue, Mar 6, 2012 at 8:52:04 AM
Members: | 2017275 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
