82 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> RCP - Problem selecting
Thu, Apr 29, 2010 at 10:26:26 AM | RCP - Problem selecting
BDerrick
3.5 Stars: 3 Votes
Revit 2010
I'm in a reflected ceiling plan and I can't select ceilings or walls.  I can select them if I drag select and filter but tab will not select either item on its own.  This wouldn't be a huge problem, however, because I can't select them I can't tag them either.  It's not a design option issue either.  Any ideas?
Thu, Apr 29, 2010 at 11:06:14 AM | RCP - Problem selecting
coreed
coreed Avatar
4 Stars: 16 Votes
until you figure out the problem, once select the item by filter, then isloate it so that it is the only item visible. then see if you can select it.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Apr 29, 2010 at 11:59:57 AM | RCP - Problem selecting
BDerrick
3.5 Stars: 3 Votes
No, it doesn't even highlight when I hover over it
Thu, Apr 29, 2010 at 12:57:26 PM | RCP - Problem selecting
coreed
coreed Avatar
4 Stars: 16 Votes
is it a file you can post? sure sounds like design option.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Apr 29, 2010 at 3:46:43 PM | RCP - Problem selecting
BDerrick
3.5 Stars: 3 Votes
The file is too big at this point. The problem occurs only in that reflected ceiling plan view.  I even tried to make a new ceiling plan but it has the same issues.  Could it be View Range?
Thu, Apr 29, 2010 at 6:58:56 PM | RCP - Problem selecting
coreed
coreed Avatar
4 Stars: 16 Votes
if you can see your ceiling plan, i don't think it would be the view range. i don't think object selection can be excluded by depth if the object is visible. strange?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Apr 30, 2010 at 6:40:02 AM | RCP - Problem selecting
You can only select a ceiling from an edge, not the middle of the ceiling.  Go to an edge and tab until you see you have selected the ceiling.
Fri, Aug 13, 2010 at 2:44:32 PM | RCP - Problem selecting
rally
I'm having the same problem in ceiling plans. In some cases I'll have a ceiling that I make a callout - the elements in the original ceiling is selectable but the elements in the callout are not selectable. I've tried making a view template from the working view and applying it to the new view but that doesn't work.
This is a big problem because I cannot tag or dimension walls or ceilings. I also did a compact and purge but that didn't help - this is a fairly large central file 200mb. Please let me know what solution you came up with. Thanks.
2D light family shows too big on RCP legend
Wed, Jul 3, 2013 at 11:35:44 AM
Sconce in RCP
Fri, Jun 17, 2011 at 8:16:36 AM
New light fixture blocks out grid lines on DEMO RCP! Anyone know why?
Sat, Aug 2, 2008 at 12:15:05 PM
ceiling plan - exposed structure
Mon, Sep 29, 2008 at 11:28:23 PM
Linking RCP to main architectural model
Tue, Aug 5, 2008 at 2:52:30 PM
Page generation time: 1.0642
