102 Users Online (100 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Label Editable by Instance?
Thu, Apr 29, 2010 at 10:13:41 AM | Label Editable by Instance?
helminla
Placing a data outlet family into my project.. opening this family to edit, found that the data annotation is its own family..opening this family to edit, where i find the electrical label (currently set to B). Is there settings I can use to make this Label (the letter only) editable in my project (i.e. rotate so that it is always right side up according to the orientation of my plan, move it aside if need to make room for other objects.)
Mon, May 17, 2010 at 10:45:23 AM | Label Editable by Instance?
helminla
still trying to figure this one out... most concerned with whether or not it is possible to define the labels rotate in th families instance properties AFTER it has been loaded into my project!?!
help!
Mon, May 17, 2010 at 10:53:20 AM | Label Editable by Instance?
You have to edit the label family and reload it.
Mon, May 17, 2010 at 11:01:44 AM | Label Editable by Instance?
helminla
Edit Label Family?
I have 3 tags in this family, controlled in instance properties accordign to our firms graphic on where the data devices will be placed: floor, ceiling or wall. Could you take a look at this family, and tell me where in each of the 3 labels i control the "B2's" rotate once Loaded into a projecT?!
sorry, i'm Super lost Sad
Thanks a million
Mon, May 17, 2010 at 11:21:53 AM | Label Editable by Instance?
As I said, you have to edit the family - not controlled in the project.
Mon, May 17, 2010 at 12:29:57 PM | Label Editable by Instance?
helminla
GOOD ENOUGH. THANKS
Creating Editable Labels
Tue, Sep 1, 2020 at 7:05:47 PM
Instance Shared Parameter??
Fri, Jul 11, 2014 at 2:49:27 PM
making labels editable
Thu, Feb 12, 2009 at 1:12:47 PM
Instance Parameter to control another Instance Parameter
Thu, Jul 22, 2010 at 6:22:49 AM
label arrow and instance parameter
Fri, Jul 24, 2015 at 7:01:39 PM
Page generation time: 0.3217
