56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Changing Default Wall Joins Revit 2011
Wed, Apr 28, 2010 at 10:00:27 AM | Changing Default Wall Joins Revit 2011
jlamothe23
I'd like to change the default wall join setting to Miter.
Took a look through older posts from the other versions of Revit.
Does any one know if Autodesk has finally incorporated a way to change the default wall join in 2011?
Thanks
Fri, Aug 13, 2010 at 4:14:12 PM | Changing Default Wall Joins Revit 2011
critter
Has anyone identified whether being able to set walls to join via miter can be a default wall join? Not being able to do this causes a bust when extracting quantities of wall surface area.
Does anyone else wish that there was a toggle to make wall joins the default off
Wed, Aug 19, 2009 at 9:49:42 AM
Can you make wall joins Miter by Default?
Wed, Dec 21, 2016 at 1:52:44 PM
14
Revit 2014 - Disallow wall joins by default
Tue, Jun 17, 2014 at 10:23:21 AM
wall joins
Thu, Oct 20, 2011 at 4:37:14 PM
View setting for wall joins display
Wed, Jul 1, 2009 at 3:00:12 AM
Page generation time: 2.7517
