100 Users Online (99 Members):
Forums >> Community >> Newbies >> "Split Face" on Curved/Arc Wall?
![5 Stars: 2 Votes](/images/stars_5.gif) |
Can it be done, the feature wont let me do it?
You can't "Split" a face in a curved wall, Revit don't allow...
3 Posts No Rating |
Hi skip9, maybe this will help you. 1. Create your primary wall 2. Create your secondary wall with same start and endpoints, but with another material. There you will be notified that there is a wall in the same place. 3. Change the start and endpoint of the secondary wall, and if desired the ofset of the ground and ceiling. And voila... you can "split" a curved wall and assign different materials. Greetings Volkmar
3 Posts No Rating |
Hi skip9, forgot to mention that you have to cut the geometrie..
using split face tool on curved walls |
Sat, Oct 12, 2019 at 8:21:20 AM
Using Split Face |
Fri, Jul 12, 2013 at 11:00:40 AM
Arc Walls with curved top? |
Thu, Aug 7, 2008 at 2:04:21 PM
Split face for multi colored wall |
Wed, Oct 7, 2020 at 3:18:11 PM
Split Facing and Painting both sides of a wall? |
Fri, Jan 13, 2017 at 10:52:50 PM
Members: | 2017166 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
