47 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> export dwg with views not referenced
17 Posts No Rating |
im having a problem when i export to dwg. because revit export the views that are not referenced, the ones are not in any sheet.. what could i do to avoid this?
How did you export?
i export like the image you attached... in revit i have some views i dont need in sheets, but i work in them...so, when i print from revit, there´s no problem because this veiw tags doesnt appear in the print...but when i export...they appear in mi dwg file...thats a problem because i use my export dwg, for my clients...but they print directly from this file...so i need to configure my export properties to export correctly...do you know how should i do to avoid this veiw tags without reference? i cant delete the views from revit cause i use them to work... i attache some image to explain what i do, and whats the problem
![5 Stars: 3 Votes](/images/stars_5.gif) |
click on them and use the glasses to hide element, then apply hidden. And unhide them when you need them
- Just trying to help out while I wait in the office for my renders to complete www.danrossiter.co.uk |
Exporting views with DWG bocks to dwg. |
Sun, May 21, 2006 at 8:36:59 PM
Export 3d DWG issues |
Fri, Jun 28, 2013 at 8:27:02 AM
Referenced views floating in space |
Thu, Oct 22, 2015 at 2:43:48 PM
DWG export issues |
Wed, Aug 8, 2007 at 7:10:48 PM
Revit Export to 3D .DWG still will not export Ceiling Grid Hatches? |
Wed, Feb 11, 2009 at 4:42:25 PM
Members: | 2017104 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
