72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> revit dwg into autocad
Tue, Apr 27, 2010 at 8:27:53 AM | revit dwg into autocad
helminla
I want a dwg from revit to export into autocad so that everything in revit dwg automatically is assigned to the layers the company has been using in autocad for years.... so when i plot the dwg, it properly assigns to the correct line weights and colors based on our .ctb plot style.
make sense? any ideas?
Tue, Apr 27, 2010 at 8:36:37 AM | revit dwg into autocad
4 Stars: 203 Votes
Did you check in export Cad formats> Layers and properties? Maybecan help you...
Tue, Apr 27, 2010 at 9:22:32 AM | revit dwg into autocad
helminla
Saw that, assumed that is where I would begin.  Can i create a company standard to apply to the layer settings in all future projects too? (Much like I can press the load button in the export layers dialog box and load the AIA, ISO, Singapore and British Standards)
Tue, Apr 27, 2010 at 9:39:51 AM | revit dwg into autocad
4 Stars: 203 Votes
Change that in your "Template" file, then every time you create a project in that template, those Export CAD properties are already created, no need to change again...
Tue, Apr 27, 2010 at 10:55:26 AM | revit dwg into autocad
helminla
What is the difference in the "Projection" and "Cut" when assigning layer names and color IDs to each category (in the export layers dialog box)?
Tue, Apr 27, 2010 at 11:13:42 AM | revit dwg into autocad
4 Stars: 203 Votes
Projection= Elevations, 3D views....
Cut= Section and plan views
Check your HELP menu please.
revit to autocad-dwg to pdf
Mon, Mar 20, 2017 at 3:11:14 AM
11
Exporting Revit 2009 (.rvt) to AutoCAD (.dwg)
Mon, Jul 13, 2009 at 3:55:28 PM
Revit Export to AutoCAD DXF/DWG problems with linked files
Wed, Aug 27, 2008 at 9:42:44 AM
truncated autocad dwg
Fri, Feb 24, 2012 at 11:20:28 AM
AutoCAD DWG Blocks
Sun, May 9, 2010 at 10:43:14 AM
Page generation time: 2.1327
