Hey Revitcity i just installed revit on my laptop... and click on the Revit shortcut, it takes a while to load and then boom: " an unrecovarable erros has ocurred the program will now be terminated all of your data has been recently saved, so there is no need to create recovery files " This message is shown, and then Revit crashes... here's the journal...hope it helps ' 0:< Initial VM measure: 1931 MB available, 39 MB used 'C 26-Apr-2010 16:29:23.968; 0:< started recording journal file ' Build: 20090317_2115 Dim Jrn Set Jrn = CrsJournalScript 'C 26-Apr-2010 16:29:24.140; 0:< ->InitInstance ' 0:< VM Delta: Available -326 MB -> 1605 MB, Used +134 MB -> 173 MB 'E 26-Apr-2010 16:29:56.734; 0:< Jrn.RibbonEvent "TabActivated:Home" ' 0:< VM Delta: Available -10 MB -> 1596 MB, Used +13 MB -> 187 MB 'C 26-Apr-2010 16:29:58.328; 0:< Protein : Register Preview Factories 'C 26-Apr-2010 16:29:58.328; 0:< Protein : Create Fbx Manager 'C 26-Apr-2010 16:29:58.328; 0:< Protein : Initialize the Renderer 'C 26-Apr-2010 16:29:58.328; 0:< Protein : Before open Libraries ' 0:< VM Delta: Available -15 MB -> 1582 MB, Used +7 MB -> 194 MB 'C 26-Apr-2010 16:29:59.484; 0:< Protein : Load fbxrenderermr Plugin 'C 26-Apr-2010 16:29:59.734; 0:< Protein : After open Libraries 'C 26-Apr-2010 16:29:59.734; 0:< Protein : 3rd Party plug-ins initialization 'C 26-Apr-2010 16:30:00.046; 0:< Protein : EmitPluginsEvent 'C 26-Apr-2010 16:30:07.281; 0:< Protein : Register Output Factory ' 0:< Autodesk Revit Architecture 2010 ' 0:< load point = C:\Archivos de programa\Autodesk Revit Architecture 2010\Program ' 0:< this journal = C:\Archivos de programa\Autodesk Revit Architecture 2010\Journals\journal.0001.txt ' 0:< VM Delta: Available -42 MB -> 1540 MB, Used +53 MB -> 247 MB ' 0:< Journal Init 'H 26-Apr-2010 16:30:10.968; 0:< Jrn.Directive "Version" _ , "2010.000", "1.833" 'H 26-Apr-2010 16:30:10.968; 0:< Jrn.Directive "Username" _ , "Neto" 'H 26-Apr-2010 16:30:10.968; 0:< Jrn.Data "JournalDefaultTemplate" _ , "..\..\..\Documents and Settings\All Users\Datos de programa\Autodesk\RAC 2010\Metric Templates\defaultMetric.rte" ' 0:< Log Summary ' 0:< .Tuning ' 0:< ...ElemTable = 1 (Serial) ' 0:< ...Global = 2 (SizeSegregating) ' 0:< ...PoolGlobal = 1 (Pool) ' 0:< ...PoolScalable = 1 (Pool) ' 0:< ...PoolTreeNodes = 0 (Allocator) ' 0:< ...Scalable = 0 (Scalable) ' 0:< VM Delta: Available -47 MB -> 1493 MB, Used +15 MB -> 263 MB 'C 26-Apr-2010 16:30:14.906; 0:< ->processShellCommand 'E 26-Apr-2010 16:30:14.906; 0:< Jrn.Command "Internal" , "Show or hide recent files , ID_STARTUP_PAGE" ' 0:< VM Delta: Available -12 MB -> 1482 MB, Used +1 MB -> 264 MB 'C 26-Apr-2010 16:30:15.296; 0:< <-processShellCommand 'C 26-Apr-2010 16:30:15.296; 0:< ->doStartupWarnings ' 0:< VM Delta: Available -12 MB -> 1470 MB, Used +4 MB -> 269 MB ' 0:< Exception occurred ' 0:< ExceptionCode=0xe06d7363 ExceptionFlags=0x00000001 ExceptionAddress=7C812AAB ' 0:< System (KB) [Available / Total ] [Revit Memory Usage (KB) ---------------- ] ' 0:< RAM Statistics: 276060 / 981860 327444=InUse 327532=Peak 378356=DeltaForRevit ' 0:< VM Statistics: 1505724 / 2097024 275504=InUse 275568=Peak 315796=DeltaForRevit ' 0:< MessageBox "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files." ' 1:--API application event DialogBoxShowing returned status DidNotRaise ' 0.174560 1:<<<Raising application event ' 0:< VM Delta: Available -13 MB -> 1458 MB, Used +4 MB -> 273 MB 'C 26-Apr-2010 16:32:11.531; 0:< program terminated
